Starcraft1210
Thread starter- Joined
- Jul 31, 2016
- 2
Hello all here on iboat! Newbie to the forum so be nice!
My 1958 johnson seahorse 10 was running great then it started missing and died! I limped back to the ramp on the trolling motor and loaded her up. I popped off the flywheel as soon as I returned home and found a horror story! It seems the spring under the cam chewed half way through the cam!
Now, I also found the graphite seal was in many pieces and suspect a hunk of it came out and lodged under the brass retaing washer and increased the pressure of the spring burning out the upper retaining washer and aloud the spring to eat the cam.
I bought new seal, o ring, retaining washers, spring and cam with points to reassemble but i do not want to have this happen again so can anyone explain installation procedure of said parts? Do i need to use a certain lube on anything? Did pulling the flywheel blow the seal out? I used a harmonic balancer puller. Any help out there?
