- Jul 23, 2011
- 52,417
so why not a boat now??
because race vehicles, cars, trucks and hot-rods dont get wet, so the $.20 chinese switches may work for a few weeks in a car, any moisture and the marginally plated material will rust up like crazy. also anyone with any experience and training avoid the chinese ebay switches, panels, and gauges like the plague. nothing but trouble and the worst thing for a race car or hot rod is for the ignition switch to be intermittent or kill the motor due to vibration and loosing contact. Every one of my hot rods was powered by a keyed ignition switch or a tyco toggle switch and a cole hersee push button
and then there is the magneto ignition issue. that you simply ignored even though there are now 4 posts pointing it out.
we are here to help, as all on this site promote proper and safe boating, as well as learning. we do not spoon feed you. if we tell you to go in a direction or to not go down a path you are trying to go down, its for a very good reason
to get the motor to start, disconnect all the wires and turn the motor over. to get it to stop, short the ignition to ground
please research magneto ignition and IP66 switches and SAE J1171 compliance
