purchase wick for 9.5 stator plate
capnwill
where would one buy the wick neccesssary for the stator plate on my 9.5 evinrude motor. any help would be appreciated. thanx bill
WillyBWright
Re: purchase wick for 9.5 stator plate
As I recall, there is no separarate part number for those. They come with the factory points and I don't remember them coming with aftermarket points. Since there are 2 sets of points on twins, each set of points comes with one which leaves one spare wick since you only need one on the mag plate. I used to toss the spare in my toolbox, but I haven't worked on a points motor in so long that I don't have anymore. But many mechanics probably do. You might be able to just ask for one from a shop. Otherwise you have to buy a set of points.
Paul Moir
The aftermarket points come with a little capsule of grease instead of a new wick. You can just lube up the cam with that. Also, you can reoil the old wick with light machine oil. If the wick is really bad, in a pinch I've replaced it with some new heavy felt. I never got a good feeling from using just the grease.
OBJ
You might try your local John/Rude dealer. They may have an extra wick laying around. The PN is 581011 and are still available from BRP. A wick from a later 9.9/15 (PN 581010) would work, I think. One of them was longer than the other, as memory serves... :)
capnwill
thanx!! u guys are great!!
DHPMARINE
I think you'll also find the wick in a tune up kit<br />which gives you 2 points and 2 condensers.It may be a better purchase.I don't have the kit number or price,but the wick alone is $3.16.<br /><br />DHP
OBJ
Tune up kit PN 172522....about $20. Wouldn't hurt...... :)
surlyjoe
I got a yard of the heaviest felt they had at the sewing shop for $6. it's the same thickness and enough to make a few hundred with and still have half a yard to polish DVD's and stuff with
