Pump oil out or drain it?
55evinrude
Hi there everybody i just purchased a 2012 boat with a volvo penta v8 5.0L and im wondering when it comes time to change the engine oil should i use a pump or the drain plug? theres not a lot of room under the engine so im guessing you have to use a pump. there is threads on the oil dipstick for a pump i assume? what do you guys think. thanks :)
55evinrude
Re: Pump oil out or drain it?
ok thank you very much Don S :D
I ran a test a few years back.
I pumped the oil out via the dipstick, then pulled the plug to see whats left.
Basically nothing! So I stopped worrying!!
ENSIGN
Pump it out,you don't want to create a leak where the dipstick attach?s
QC
Manual pumps work fine. Remember to warm the oil first ;)
Just a friendly reminder, and this thread is generic enough so no biggee, but we really recommend starting your own thread for technical topics.
55evinrude
hey one more question guys. all the oil pumps i see you put the tube down the dipstick, but my dipstick isn't big enough for that..... I noticed there are threads on the top and i seen a video when the pump threads on the top. where can i get one of these pumps (besides Volvo)
Nathan
Nathan
Ayuh,..... I sprung, 'n bought the Mouller "pump it, 'n walk away system" a couple years ago,....
I've been kickin' myself in the butt ever since,...
I shoulda bought it YEARS ago,........:facepalm:
It's got Several different sized tubes, 'n an adapter to screw onto yer dipstick...
Dave88LX
Thanks for the info.
Understood on starting your own thread, but I figured being a question that has probably been asked a million times, I would search for an answer instead of making a new redundant thread and gotten a "GTFO noob do a search!" ;)
55evinrude
Thanks bond-o those pumps look great! I have heard they pump quick also!!
Nathan
StatRX67
Get a female garden hose fitting with a nipple that fits into the tube that you'll be running to the pump. If it's what I have on my 98 it will fit. I use the venturi type pump with an air compressor and it empties the crankcase real quick.
bnicov
Manual ones work fine, if you are only doing 1 oil change per year on your boat, then it's not worth the money to get an electric powered one.
bruceb58
My that's a lot of options! With a small 3.7L and easy access, does one really need the electric pump for 5-6 quarts? Or is a manual one just fine?
Thanks.
- Dave
On Volvos, the dipstick tube that you suck the oil out of actually connects to the oil pan drain hole which is not how yours is set up.
Fishtales22
The vacuum type oil pumps work best. No need for an impeller type pump. A hose from the pump slide down the dipstick tube. Make sure the oil is hot. If the oil is cold it will be too viscous to pump out.
bruceb58
On Volvos, like the OP has, you want to have a pump that has the hose fitting to screw onto the dipstick, not the type that slides down the dipstick. It doesn't need to be nearly as warm that way either if needed.
I see you also have Volvos. Why not get an adapter that screws onto your dipstick?
bransjeep
you could always get a fumoto valve and drain it that way all u have to do is attach the right size hose to the end of it and run the hose out of your hulls drain plug hole to a contanier and its a done deal. then u close the valve and fill
bruceb58
LOL...why when the dipstick goes into the drain plug already on Volvos?
Fishtales22
The pump I have uses a tube and the vaccum seal is maintained by a rubber "cup" that inserts into the dipstick entrance. I have been using it for 10 years. Oil is removed in about 5 minutes after just a few plunges on the pump.
