Proud owner 1983 70hp jhonson
giant78
Hay guys new here thank you for all the information youyou guys give on this site.
I have ? Will a bad top & bottom crank bering & seal give the engine that lack of fuel symtoms wen you demand fuel on the throtel wen triying toget going
D
DJ
Guest
Re: Proud owner 1983 70hp jhonson
Probably not. You probably have a mis-adjusted engine and/or carburetor troubles.
giant78
Mr. Supreme marine can you explain that mmis adjustment .
Not to disrispecful .
Randybeall
Bad crankcase seals can cause fueling problems. Most likely would be hard start when you would not have enough crankcase vacuum to pump fuel. If you use the primer bulb this would be eliminated. Acceleration would be the next most likely case since air flow would be less than needed to pull the normal amount of fuel from the carbs. Top and bottom cylinders might run lean. Perhaps a plug check would be of assistance.
I would guess that a careful full adjustment process would eliminate your problems. Look in the frequent problem post at the top of the engine section. There is a listing for setting wide open throttle from Joe, who is a long time tech. It works, that and a careful throttle throttle syncornization frequently fixes this kind of problem.
Randy
