Props for 93 force 120
flightdoc
Question for the experts on this forum. Am I limited to the 3 blade props I read about in different Magazines and online or can I use any thru hub exhaust prop. I ask because I would like to get a 4 blade prop to make pulling a skier a little easier out of the water but I don't see any place where it lists 4 blade props for any Force Motor.
Moderator, if this is posted in the wrong forum sorry Please move to Prop section.
SparkieBoat
Re: Props for 93 force 120
go to the prop section here at i boats and look at props listed for your motor...if they have it listed for your motor it will fit..i see no reason you could not use a 4 blade prop. What is your top RPM with the prop you have now and what size prop is it???
flightdoc
So far every section I have checked only sells 3 blade Props. I have found 4 blade Props with the same spline tooth count and through hub exhaust being sold for mercury motors so I will give that a try unless someone can recommend why that may be a bad idea.
