proper way to strip gelcoat
plane_crazzy
I have a 1958 Larson fiberglass boat. sadly the gelcoat is majorly cracked and faded from age. I am considering stripping the entire boat and reapplying gelcoat. However, I am unsure the best way to strip the gelcoat without damaging the underlying fiberglass. any advise would be helpful, thank you
Woodonglass
Re: proper way to strip gelcoat
You don't strip gelcoat. You have to Sand or Grind it off down to the fiberglass.
plane_crazzy
my apologies, I didn't mean strip as in chemical striping. I am asking if there is a technique or tool that is better suited to physically removing the gelcoat.
Woodonglass
probably the best tool is a 7" Grinder with a backup pad and 24 grit resin coated sanding discs. thats for the Hull for the top cap where you've got nooks and crannys a 4 1/2" grinder with same setup or a R/O sander. It's a LOT of work and requires a Really Good respirator, preferably a Full face one. Tyvek suit gloves etc.
make sure you have the proper PPE
plane_crazzy
how resistant is it to an abrasive blaster? I own a sandblasting unit, obviously I dont want to cut clear through. but would very fine abrasive be the best option?
Woodonglass
Yes, you can remove it via sandblasting but if you are not really good at it I would thinkg twice before doing it. If you go through the glass you'll have a problem. I will take a lot of blasting media and create a mess IMHO. If you have a facility to do the blasting then it is an option
ondarvr
How much does this boat mean to you and just how bad is the gel coat? Removing all the gel coat and then respraying it, fairing, sanding and buffing is a huge project.
Some pics would help in giving you some options.
CaptainKickback
I will be re-gelcoating my project boat (1981 Sea Ray) and although I haven't done it yet, I have done a LOT of reading, especially here on iboats. Here's what I've learned and plan on putting into practice:
1) You likely do not have to take off all the old gel coat. Get the dead stuff off and get rid of any spider cracks. If there are any major cracks, investigate the cause so you can fix any structural problems.
2) Do not use a circular sander, and definitely not 24 grit (that's grinder class). Yes, it will take it off and in a big hurry. I've been told by experts you will never get the gel coat off without deep scratches and gouges in the fiberglass or remaining gel coat with a disc sander. I played with my 7" sander/grinder with 80 and 120 grit and could not do it without the scratches and gouges. Experts have also said you will get a wavy, uneven surface if you use a disc sander.
3) Use a random orbit sander. Try 80 grit, but go to 120 grit if you are getting marks.
4) Outside corners will sand off easier, so you have to be careful around these. You may need to do hand sanding on these spots and for inside curves and corners as well.
5) Go down to bare fiberglass where you need to fiberglass something new onto that part of the boat. The new fiberglass doesn't like to stick to gel coat.
6) Use fairing compound (you can make your own or buy it) to fix imperfections in the surface.
7) Final sanding should be 80 or 120 grit.
8) Read a lot here on iboats before you start.
Hope this helps. Good luck...
plane_crazzy
I havent totally decided to go through with the full strip down to fiberglass, just considering it. It may be possible to patch it up, not sure yet. just trying to research all my options first.
KC4ZQZ
Kick Back, How do you make your fairing compound? The various coumpounds I've seen on line are kinda' pricey. I was thinking about mixing some polyester resin with silica and maybe some microballoons to fair some areas on my deck. What do you think?
CaptainKickback
Yeah, it does seem pricy. But when you and the cost of your resin and whatever fillers (lots of filler) you use, the difference is not so pronounced.
Everyone probably mixes their fairing compounds diferently. What you want to achieve is a paste that doesn't run or ooze when you put it on, but is thin enough it spreads easy, even into tight spaces. You want it to provide a smooth, unpitted surface, and you want it easily sandable.
Havibg said that, microbaloons will be your #1 filler. It will take a lot of it. Mix in some silica (brand name Cabosil) where you need a bit more hardness, but it will make sandind a bit harder.
I suggest you buy a quart of fairing compound and use it first. That way you will know what your target looks like if you decide to mix your own.
Sea ya...
