seldomseen
- May 15, 2006
- 29
Re: Proper Prop Pitch
Keep in mind that the production two stroke outboard is a very low compression machine with equally low volumetric efficiency. The things that work on a four stroke have only a little corelation to a two stroke. With a four stroke over proping to yeild a WOT rpm of 20% less than the manufacturers reccomendation would have one good result on an average boat instillation and that would be increased gas milage. The four stroke is most efficient at WOT and low rpm. This is why gas engine airplanes run WOT at cruise but run the prop pitch so high that the RPM is LUGGED down such that the HP output is approx. 70% of the HP at WOT and max RPM. The overproping on the four stroke could have bad results also and the worst is an inability to acheive a planing speed on a planing hull.
The two stroke overproped 20% will not increase the MPG to a marked degree except to the extent that the slower speed on the boat might put it at a more efficient speed. Do not be afraid to "LUG" a two stroke as regards damaging your engine.From the engine damage standpoint I think that an extreme overprop on todays two strokes such that it's WOT RPM was 50% of reccomended WOT RPM would not hurt the engine at all. Just make sure your water pump is good.
