Proper mounting of kicker motor vs. hull depth
Afinelli
I'd like to get rid of the adjustable, external engine bracket that my 6HP Evinrude kicker motor (1996 E6RLEDS) is mounted on, and mount the motor directly on the starboard side of the transom of my 17' Boston Whaler (1967 Sakonnet -- predecessor to the Montauk). What I want to know is what determines whether I have enought shaft length on the motor to do this. Is it ok if just the prop and water intake will be below the water line when the motor is used? Must both be below the hull at the point at which the motor is mounted? Must they be below the lowest point of the hull at the center of the boat? Is there some other determining factor? Thanks for the help.
