Proper Gas/Oil mixing ratio??
turtle1173
I have a 1975 55 HP Chrysler. I am rather new to this but what should the gas/oil mixture be? On the back of the carton it has 100:1, 50:1, 32:1, & 16:1. I have heard of people using 50:1 but it seems like I read somewhere that 32:1 is much better. Any suggestions out there?<br /><br />Thanks,<br />Shane
seajay
Re: Proper Gas/Oil mixing ratio??
i believe the older motors ran a 100 mix but with a 50 i think u still get the lube requirement.
MIKE F
turtle,<br />I think you'd be fine with the 50 to 1(definitely not 100 to 1).The 32 to 1 would probably foul the plugs too easily. I think32 to 1 was for older engines than yours. ;)
turtle1173
Well, if 50:1 is the right ratio, that will work out good considering that I have a 6 gallon gas tank. The 16 ounces of oil make it just right. :) <br /><br />Shane
MIKE F
turtle,<br />Don't go mixing anything yet. Notice I said think as in pretty sure.Wait for others with older engines to post. ;)
norman158
i have ran 50 to 1 in my 45chrysler for years
mnmfors
I had a force, ran 50:1, ran great. I am not sure it that is what it called for tho.
jrbpit1
I have an 84 75hp Chrysler OB, I run 50:1.<br /><br />JRB
