propellers
eastes
i'am getting new prop an changing the pitch from 19 to 17 pitch, do i need to replace the thrust washer or can i use the same one? eastes
Dhadley
Re: propellers
Depends. If your old prop had a fixed rubber cushion hub and the new prop has a removable hub system then you'll need the right hub kit.
