burtonrider11
Thread starter- Joined
- Jul 28, 2005
- 178
Hello, trying to dial in a new (to us) boat. Earlier this season we bought a 1997 Starcraft 2010SS with 5.7l Merc, 2 barrel carb, 235hp. The boat came with a 4 blade 22", 3 blade 19", both stainless. Also a 3 blade alum which will probably just sit in the garage
Alpha Gen 2 drive with 1.62 gear ratio
When I bought the boat, the owner had said that in optimal conditions IE, just him and a quarter tank of fuel, he has seen 54mph via GPS. I thought that sounded about right based on weight and horsepower, unfortunately, he didn't say which prop....
In any case, out yesterday with 4 adults and two young children, gear and 3/4 tank of fuel. I finally opened it up. Top speed was 45.2 (GPS) at 4400 rpm and this was with the 4 blade 22" stainless. I believe it is an Apollo XHS. I was thinking that even with this load, I would see something in the upper 40's. We were working our way up river as well (Grand River for those of you in Western Michigan). Does this sound about right? Using a prop slip calculator, it calculated to 21% slip, is that accurate or do I need to perform testing with just me and low fuel and gear.
Also, does this prop seem like the correct prop? To me, it seems a tad big despite the fact that I am right in the correct rev range (4200-4600) assuming the tach is correct. I can't seem to get the 19" on the prop shaft for some reason, but that's another story. The 4 blade doesn't seem to provide a ton of bow lift and is slower to plane that I would like. Top end isn't really what I am looking for, I'd rather have a good cruise speed at 3000-32000 which is 28-32mph and better hole shot. We typically cruise with at least 2 adults, 2 kids. Maybe I should just be happy with the 4 blade?
Just looking for some feedback on whether I am propped right or not. If not, if there are any recommendations...Thanks in advance!
