PatinIdaho
Thread starter- Joined
- Oct 7, 2014
- 443
Boat is a 1984 Bayliner 24.5 Ciera. AQ225D/280
Original prop was tore up kinda bad and it is a 15X17 Michigan. Don't know how its performance was to well as it was a test ride and i could not see any sense in running it hard with a prop in bad shape.
So today me and the wife had it out at the lake. Get home and checked performance numbers.
I had put a new Solas Amita 3 that i had on hand on it. 15-1/4X19 cup and it seems to thoroughly suck!!!!
3200 RPM, 25 MPH(gps)
3800 RPM, 30 MPH(gps). WOT could not get anymore out of it.
IF im reading the prop calc right it is giving me 30% slip at 25mph and 29%slip at 30mph.
IBoats lists the weight at 4550. Had 2 adults #350 and some gear maybe #35, about 40gal fuel.
What would you suggest i switch to given the above numbers?
Also originally bought this prop for a 18F TriHull with a AQ225D/280. I remember how bad it sucked on that also.
