atthelastminute
Thread starter- Joined
- Jul 11, 2007
- 21
I want some opinions on my prop selection. I recently replaced my outdrive with a sterndrive unit and purchased a piranha prop at the same time. I got two sets of blades, 14x19 and 15x17. This weekend with my engine finally tuned to what I consider to be perfect, on reasonably smooth water I got 28mph at 4600 rpm with the 15x17, and 33mph at 3980 rpm with the 14x19. My engine WOT range is listed as 4200-4600 on the engine. Running Piranha's prop finder on the 14" prop specs it says to go to a 15x19 prop, but normal logic says that would make the engine run slower. Anyone have any input on what would be my best choice here?
By the way, I am using a speedo for the speed, and a digital tach off of the #1 plug wire for the rpms.
Thanks,
Thanks,
