Prop size
Sullygee
Got 88 Jhonson 110 with 13.1/4 15"P on 86 16' starecraft 16' bow rider. Change prop to 12 3/4" 23P. Good/bad idea?
JimS123
Without rpm data it's just a guess.
But for sure, if the 23P works, the 15 pitch must be Reallllllly BAD.
Most prop changes are 1 or 2 inch pitch changes. Going up 8 inches sounds like a disaster.
Sullygee
Thanks that's why I ask. Will go maybe with 17. The last time our had it about 3400 rpm but not wot.
Chris1956
You really need to run the boat at WOT. If the RPMs exceed 5500, then prop pitch needs to go up. Figure on 400RPM drop for every 2" of pitch added to prop pitch.
JimS123
Why change at all? What's wrong with your current prop?
Provide more details and we can better advise.
Sullygee
Will try that next time out. Or will stay what I have as JimS said. I'm trying to understand props will get back with better info. Thanks again
Chris1956
One more thing. Run boat at WOT with normal load and max trim and then record max RPM.
