prop size
jc44
just bought a 97 crest 111 pontoon with 27" tubes.has a spare prop on now ,dont know size yet will look later,motor is a 1976 75hp johnson, now does 13mph at 4200 rpm,any ideas where to start for right prop. thanks.
crb478
Re: prop size
See what the pitch of the prop you have now is. You should be turning 5000-5500 rpm and the higher the better. I suspect that you need around a 13 pitch prop or maybe even an 11. I am a fan of four bladed props on pontoons, I believe they run smoother in the turbulent water behind the pontoons, but that they also give you better control in reverse.
MH Hawker
Re: prop size
I would think with a 75 hp you snould be running in the 20 mph range.
jc44
Re: prop size
thanks for info, boat being delivered in a few minutes,will post results after checking prop.
jc44
Re: prop size
the original prop is not on the motor as it was damaged,it isa 13x17,the previous owner said ran decent.wondering if i should try a lower pitch around a 11 to 15?
steelespike
Re: prop size
A 17 seems like a lot of prop.Your present wot rpm and gps speed will help determine the best prop.
crb478
Re: prop size
I would drop to al least a 13 but probably an 11 pitched 4 blade would be about right
jc44
Re: prop size
pulled prop off motor,had to go by serial number,no size stamped,took it to shop guy said it was 133/4 by 15. ran boat boat in the river where it was calm,most i could get was 16mph at 4100 at wot. how much should i go down on pitch,11,12,13????. any suggestions would be appreciated. what about a 4 blade?. thanks.
crb478
Re: prop size
If you are only getting 4100 rpm with a 15 pitch you may need to go to a 9. I believe that motor should be turning 5000-5500.
lakegeorge
Re: prop size
I would go to the 11 pitch.
jc44
Re: prop size
thanks will do. sorry i just noticed i had repeated my-self in an earlier post.
