Prop shaft wear
kevinwd1
After pulling the gearbox apart on my motor (1962 28hp) the prop shaft has small groove in it. Its right where the prop shaft seal rubs against the shaft and I'm not sure if it?s normal or I should be worried about it. The groove is very narrow and even, it almost looks like it may have been machined into the shaft. I just don't want to waste my time repairing the gear box if the prop shaft is worn out
Re: Prop shaft wear
???? Was there water in the gearcase ???--------Did you pressure test the gearcase before taking it apart ??----------A new seal there will help.------Reseal it , assemble and pressure test it.-------Is thre nobody down under with bins of good used parts for these ???
