Prop shaft seal
Downwindtracker2
I replaced the seal as it had leaked and bearing when I was put together one from two on '76 7.5. After adjusting the idle in a barrel,I have one inch oil spot under the leg in the garage. This is the second time. This doesn't seem normal. I didn't feel a groove when I installed it. Lips to the inside.Fill with grease.
