prop shaft runout?
av8erdunn
Does anyone know what the max prop shaft runout is on a DP-SM lower unit?
Ayuh,.... Basically, if it's visible, it's Too bent,....
Merc says .005" is the limit,...
Ostsideend
I guess you are having a VP?
Volvo says for 280DP, 290DP and DP:
0,0027" max runout gauged from the outer (tubular) to the inner shaft.
0,0012" slack when pressed the inner- towards the outer shaft.
av8erdunn
But if volvos specs for max run out only 0.010 you would never see that with a naked eye. That's why I will use a dial indicator to measure.
jerryjerry05
You'd be surprised what your eyes can see.
Remove the prop and start it up.
Put it in gear and see if it has ANY wobble.
I was doing a LU service on one of my motors.
I removed the prop and greased the splines.
For some reason I spun the prop and noticed a big wobble.
Luckily it was just the prop and I had a spare.
Somehow the hub/ prop slipped or I hit something and it moved???
