180Diablo
Thread starter- Joined
- Mar 8, 2007
- 76
Ok, the prop I currently have installed is the Merc Black Max (stock) prop # 48-78120A40 19P. Last weekend I noticed that one of the blades has been bent out of shape a wee bit and a small gouge is in the same blade as well. Could have been from striking an underwater deadhead this past weekend, could have been there since I bought the boat last September and only just noticed it last weekend. Either or, looking for a spare as well as a replacement prop.
So when I visit the local marine supply store, he informs me that I would have to update the prop AND hub to the new Flo-Torq II design, because my prop design does not have the plastic removable hub design. He also mentioned that unless he could find a rebuilt prop of "my design", I couldn't really re-use my current prop (once re-conditioned) unless I changed everything over again. Which im not sure how much of a difference in mounting the two different setups would be. I have not seen a Flo-Torq II design removed from a sterndrive.
Are these older design parts worthwhile to continue using or am I better off updating my stern drive to this Flo-Torq II designed hub & prop?
In reference to my attached below photo, #64 through 68 are identical to what I removed. The other parts I did not see, which could have been buried inside the prop and came off all in one shot.
thanks to any replies
