Prop Rotation
Chuck4741444
I bought 2 96 johnson 200
Model # j200txedr
# j2000xedr
My research shows they are both clockwise, standard rotation.
I only need one, which one is standard? They came off the same boat so I assume1 is clockwise. And the other counterclockwise, The came without props.
There is no need for one to be counter rotation!!----Neither model number indicates or hints of counter rotation.
saltchuckmatt
With the motor off, pull the plugs, put it in gear...and turn the flywheels clockwise while observing the prop shafts.
To answer your question, clockwise is the default.
Chuck4741444
I spoke with the previous owner about getting my titles.He says one of them is counter rotation.
Thanks, I will do more research, im installing one next week.
The other options as mentioned before is to pull the cover, pull the plug shift it in foward gear and see which was it turns.
L ast question. Dose the shifter pull foward or backwards to go in foward gear?
Crosbyman
it is simple
96 johnson 200 Model # j200txedr & # j2000xedr
You’ve got two model numbers there, but one of them is likely a misreadβ€”and neither of them indicates a counter-rotating unit.
πŸ” Correct decoding​
1) J200TXEDR
This is a valid 1996 Johnson 200 HP model from Johnson Outboards
  • J = Johnson
  • 200 = 200 HP
  • T = power trim & tilt
  • X = 25" shaft
  • ED = 1996
  • R = revision/version
βœ… Rotation: Standard (right-hand)
2) β€œJ2000XEDR” β€” not a valid model
There is no 2000 HP Johnson, so this is almost certainly a misread of:
πŸ‘‰ J200TXEDR (same as above)
or possibly J200CXEDR (if the β€œT” was actually a β€œC”)
⚠️ Important (your actual question β€” counter rotation)​
  • J200TXEDR β†’ NOT counter-rotating
  • If it were counter-rotating, you would see something like:
    • J200CXEDR (C = counter rotation)
βœ… What you should do to be 100% sure​
Because letters can be misread on old tags:
  1. Re-check the plate carefully (clean it if needed)
  2. Look specifically for:
    • β€œC” in place of the β€œT”
  3. Or do the physical test:
    • Put in forward gear (engine off)
    • Spin prop:
      • Clockwise β†’ standard
      • Counter-clockwise β†’ counter-rotating
🧠 Bottom line​
  • J200TXEDR = standard rotation
  • Your second model number is almost certainly a reading error
  • Only a β€œC” model would be counter-rotating
And here I thought the letter----N----was for counter rotation in the 96 model year.
Chuck4741444
it is simple
1) J200TXEDR
  • J = Johnson
  • 200 = 200 HP
  • X = 25" shaft
  • ED = 1996
    • Spin prop:
🧠 Bottom line​
The numbers are hard to see. I bet the J2000XEDR is actually is J200CXEDR thanks,
saltchuckmatt
Lol, nobody seems to want to answer your question...you pull it forward to get it in gear.
Cheers
saltchuckmatt
it is simple
1) J200TXEDR
  • J = Johnson
  • 200 = 200 HP
  • X = 25" shaft
  • ED = 1996
    • Spin prop:
🧠 Bottom line​
Hey Crosbyman....does chat gpt do all that or do you lay out all that stuff?
Crosbyman
Just ask the question copy paste ...simple but it is a machine and known to have been wrong. you can even ask about your aching bones ! :) IT will search the world and reply
saltchuckmatt
it is simple
1) J200TXEDR
  • J = Johnson
  • 200 = 200 HP
  • X = 25" shaft
  • ED = 1996
    • Spin prop:
🧠 Bottom line​
  • Just ask the question copy paste ...simple but it is a machine and known to have been wrong. you can even ask about your aching bones ! :) IT will search the world and reply
    I just might do that!
