Prop Question 1988 80 HP Mercury
Starman
I have a 16' Starcraft aluminum boat with a 80 HP Mercury. It has a 21P prop. This seems high. Don't have a tach. Boat runs 35 mph at wot. Doesn't sound like its getting all the rpm's. Any help appreciated.
Re: Prop Question 1988 80 HP Mercury
Ok, How accurate is the speedometer? You can use the prop calculator to see what the RPM is predicted to be given a likely slip factor.
Realistically, to fine tune this application, you will neeed a tach. Does the motor have PTT? If not, you will have a real hard time to get top RPM.
