kcseasprite
Thread starter- Joined
- Sep 17, 2009
- 16
here's my info: Model 1977 1782 Cougar BR, made by sea spriteby united marine. Lenght: 17"4ft, beam: 82", weight 1150lbs dry, type: runabout / Tri hull, max capacity: gear, boat, motor 1700lbs. trans height is 20" max horsepower power rating is 130HP. My motor 1977 115hp mercury, final drive ratio: 2:1, Max speed acheived 25mph with paddle wheel attached to hummingbird 565 fish finder. This run was with me in the boat with my normal gear and about 7 gallons of gas. I weigh 150lbs so total weight with just me in the boat at full throttle should be about 1800 - 1850lbs. The prop on the boat now is a factory mercury prop 4865024 A1 19P. I do not have a tach. Please help.
