prop on 40hp jhonson
teelaw64
looking at prop to get more rpm. theres a key way with no key and keyways on shaft is smaller then the one in prop. but theres a sherr pin though. as much as can find stamp on front hub says p j 40 looks like you could put bigger dia prop on. im not sure of pitch .1976 jhonson model 40 el 76r
F_R
Honorary Supreme Mariner
Re: prop on 40hp jhonson
The keyway in the prop is not used for anything, it is used only for assembling the prop at the factory. PJ-40 is an aftermarket prop made by Michigan Wheel Company. I don't know the size offhand.
Daviet
What RPM is the engine running now at wide open throttle?
I think the standard prop was 10 1/2 X 13, with 4 or 5 different sizes available.
You need to know what RPM you are turning now to guage what prop you need.
teelaw64
well it dont go very fast gps shows 12mpr i don know rpm how do i check
steelespike
If you read the stickies at the top of the page and get us all the info you have about the boat and motor.An induction tach like a Tinytach will get you the rpm.
If you have some sort of reasonable size/weight boat at 12 mph you have problems other than a prop.Do a compression check.Very likely you are running on one cylinder or throttle not opening all the way. Check the spark,observe the movement of the throttle.
