Prop Hub Compatibility
iaboat
Hello, I recently had a prop hub fail on my boat with 79 mercruiser 260 engine. The propeller is a mercury 46-74266 , which looks to be superseded by 16316A46. I can tell this prop has an older style pressed in rubber hub which from what I have researched is not compatible with the flo-torq 2 kits (I have not been into boats very long so correct me if I am wrong).
Does anyone know where I can get a kit for this prop and is it something I can press in myself? Finding compatible parts for this boat has been a nightmare in the past so I want to make sure I purchase the right thing.
Thanks!
GA_Boater
A prop shop can re-hub your prop. Very doubtful you can do it at home.
Look at your post to see where to buy new, then you can use a pressed hub or a hub kit.
