prop help
trider
I've got a 372 ranger bass boat with a 1991 115hp mercury. I run WOT and can run around 6000 rpm and blow the prop out. should i chage prop size and how much more pitch. thanks
usskydvr
Re: prop help
You didn't say what your current pitch is. Generally speaking if you are over reving you engin then you can handle more pitch ( 2" increase will drop RPM by 300-400), but first you need to make sure you are coming out of the water with too much trim or height (if you run a jackplate)
