prop&gear
ewwod
hi
i recently put a new prop on,i now realize that the engine was in gear when i did this. now when i try to start the boat it wont go into neutral or reverse just forward .
replacing prop due to hitting something
what am i doing wrong ?
Don S
Re: prop&gear
Moving to Prop Topics and Questions forum.
Silvertip
Re: prop&gear
Installing a new prop should have no affect on shifting from neutral to forward or reverse. The reason you can't shift properly is because you hit something and damaged the lower unit in addition to the prop -- not because you changed the prop.
Don S
Re: prop&gear
Can you turn the prop by hand, either direction?
ewwod
Re: prop&gear
hi
yes the prop turns in forward gear only,it wont go into neutral or reverse
thanks
