Prop for Yamaha 60 hp 4str on Lund Alaskan
trout21
I have just put a new 60 horsepower Yamaha four stroke on a Lund Alaskan. The boat ways about 750 pounds not including the anchor and fishing stuff I put in it which probably isn't that much additional weight.<br /><br />I do not have a tach for it. Does anyone have experience with this to recommend the correct prop?
walleyehed
Re: Prop for Yamaha 60 hp 4str on Lund Alaskan
This is going to vary greatly between 2 boats of near the same design due to weight, hull configuration, etc...<br />The best investment you can make is a tachometer...that's the gauge that tells it all.<br />You will have no other way to tell if you are running the right prop or not, without one...
rickdb1boat
You can try here, but it will only give you a ballpark to start in:<br /><br /> Michigan Wheel
