prop for 75 HP Optimax
rsimmons42
I have just purchased a 2008 75 HP Optimax that is not coming with a prop and need to know what size to get.
I have a 1989 sunbird SPL155 it's just shy of 16' and dry weight of 1200lbs. I would like to know what size prop for this application.
Thanks in advance.
hwsiii
Re: prop for 75 HP Optimax
Rsimmons. you need a 16" Pitch prop and that will push your boat to about 32MPH with close to maximum RPM.
H
Silvertip
Honorary Supreme Mariner
Your motor has a 2.33:1 gear set and if properly set up can run a 13-3/4 x 19P prop. I own a larger boat with approximately the same weight with a carbed 75 HP that runs a 13-3/4 x 19 aluminum prop at 5250 RPM. It also runs much faster than 32 MPH. That would at least be my suggested starting point. An efficient stainless prop in the 18P range would probably provide very close to optimum performance. I feel 16P is way too little pitch.
hwsiii
Rsimmons, I think you ought to try Silvertips suggestion and try a 19" Pitch and we will easily be able to tell which one is right. If my calculations are right you will be turning less than 5,200 RPM with a 19" Pitch Prop when it ought to be turning about 5,700 RPM. There is a direct link between boat length with the same weight and Prop Pitch, on a longer boat you can use more Pitch in most cases. If you had a 14 foot boat at the same weight you would use a 15" Pitch prop and run slower.
H
rsimmons42
H
HWSIII,
I am not understanding your coment, you say go with Silvertips suggestion, then you turn around and tell me that it will not get it's top rpm. so you think I should go with a 19" pitch prop as well? My calculations put me at 17"
hwsiii
These are my calulations for your boat and motor, I have assumed certain guidelines about your boat and motor combination. Silvertip has been here helping people a long time and has a vast knowledge of boat and motor combinations. But I do believe I am correct in my calculations and I believe you need a 16" Stainless prop. Although a 17" pitch will run within the recommended RPM range of the motor, if you add a couple more people then it should not be within the reommended RPM range for the motor, or if you decide to pull skiers it will be turning under the recommended RPM. And I am of the belief that all motors ought to run in the very top of the RPM range. Here are my calulations for your setup. If my assumptions are wrong then my numbers are wrong.
Boat and Motor
Prop Picker
Prop Change
H
Silvertip
Rsimmons -- if you haven't guessed, prop selection is a real crap shoot. Charts and calculations get you close to what you need but rarely hit perfectly on the first attempt. The main reason is that everyone loads their boat differently, drives it differently, uses it differently, the engines are in different states of tune, hulls are in varying degrees of clean, and the props they select may come from different manufacturers, different models, and be made of different materials. In that regard a 19P prop from Mercury for example can be any one of a number of different "Models" each of having different performance parameters. Complicate things by comparing that prop to one from Apollo, Turning Point, Michigan, etc and you have a totally different set of parameters. In other words 19P (or any other pitch) props from several manufacturers may not and rarely do perform identically. We are providing you with a starting point. If you selected a 19P Merc prop and found it to be not correct for your application and decided to try a 17P from someone else, you may be very surprised to drastically "overshoot" your target or in some cases may see little to no improvement or even degraded performance. So unless you have deep pockets and can spend large sums of money on props, do your research well. Look for test reports on your boat, your motor, and study the test conditions very closely to make sure they match yours or are at least reasonably close. Start with the exact prop used in that test. Any other prop would likely produce very different results. Or, work with a prop shop that has a try before you buy program. A good prop shop may also be able to recommend a prop as would your Merc dealers. If the first thing they do is head for the prop calculator, be wary because their "estimate" is no better than what you were offered here. Experience and tests are the best source of data.
rsimmons42
thanks everyone, I will go with the 13 3/4 x 19" pitch prop and let you know the results.
rsimmons42
is the pitch going to be different on a stainless to a alluminum?
