stephanofd
- May 30, 2009
- 17
Re: Prop for 4.3L Merc I/O
Thanks hwsiii, I will check with the local Prop Shop to see if they have one for me to try. If not, I may go ahead and bite the bullet and buy one from iboats. I was kind of thinking that I might need to go to a 4 blade to bring up the hole shot and drop the WOT to the right range. I'm just surprised that I was actually fairly close with my original guess considering how little practical experience I have with picking props. I am good at research, and read quite a bit on this forum. That is part of the reason that I have gained so much respect for Hwsiii's opinion on props. Kind of like Don's on motors, or Ondarvr or Ooops on fiberglass.
Thanks for all the help, I will let you know my results whenever I get to try it out.
Stephanof, you need a 21" pith Solas Amita 4 blade prop, it will derease your prop slip a lot and improve your hole shot and aeleration very muh. You should be as fast or maybe faster with this prop and you will like the way the boat moves up higher in the water olumn and how smooth it runs.
H
