prop cavitation
kevincave
heres the scenario, 17 ft invader volvo 4cyl 270 outdrive. prop was a little beat up so i sent it and had it repaired by a prop shop in l.a. looks like a really good shop. they do 20ft diam props to small boats. last week out with it for the first time it was flawless smooth as could be . this week i have a severe cavitation problem. first time it happened i was running at almost wot. slowed the boat down and idled it. started to go and almost on a plane and it did it again. now soon as you open the throttle to plane it spins. not coming in or out of gear. i had it cavitate once when it had some weeds on it and it is just like that minus the weeds. no obstruction, clean hull. the boat has worked fine for the last 6 months till this weekend..any suggestions,, thanks kc
Re: prop cavitation
Ayuh,... It sounds like a spun prop hub,...
Scribe a line on it, induce the slip, 'n check for movement of yer mark...
kevincave
Re: prop cavitation
thanks bondo, you are the man!!!
