stevenj
Thread starter- Joined
- Jun 8, 2008
- 156
25930 big twin 35 electric.
Iwill try and not ramble, OEM parts manual calls for prop #277617 I currently
have a #304825 ,the best I can read from the back of the prop,the first digit hard to read but pretty sure it is a 3. Is the prop one in the same ?
Next ? is reguarding motor heigth. my anti cav plate is about 2" above the
bottom of the hull, 3 or so if going from the bottom rib.
the transom measures 20 inches, If I have to I will start the search for necessary parts to extend this motor.
I could cut a drop in the transom but would only get maybe 2 inches
which should get the plate to the bottom of the boat. the 5 inch extension
would put the cav plate about 3" below without building up the transom.
This motor is on an 04 mirrocraft 14 footer.
opinions please
thanks Steve
opinions please
thanks Steve
