Prop adapter
Boberp
I need an adapter for my stainless prop to fit the spline on the shaft but can't find anything in the directory. Any ideas?
Re: Prop adapter
You'll need to Explain that alittle Better,.......
'Cause, Basically,.....If the Prop Doesn't fit the Propshaft,.......
It's the Wrong Prop.......
walleyehed
Re: Prop adapter
Yea, give us a prop model...square hub for flo-torq? XHS? What manufacturer?
kp913
Re: Prop adapter
You must be in need of the proper hub kit, but like has been mentioned in the post's above, what manufacturer's prop do you have, what is the year make and model of your outdrive or outboard?
propeller forum dot com
