Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
Re: Project "1600 Capri Hard Top" has begun!
Have been playing around with the results of my tests. All I can say is "%&^#@%^& " that 1708 biax is like nothing I ever used before. Compared to the 6oz -10oz stuff I used, this 1708 is more like 1/4" plate steel. Its only been about 5 hours since mixed and applied, and even if I press my thumb on it will all my weight, it does not deflect and make a dent in the foam underneath. (well, maybe not all my weight, but all I could muster to lean on a portable work bench without collapsing it.) The single layer 6oz is very firm, but will deflect under pressure, and two layers on foam will be plenty strong for making things like live wells, center consols, and partitions/walls under splashwells, etc.
I still cannot believe the strentgh of the 1708. No wonder the guy I bought it from was getting irritated when I continued to question him about its characteristics and my application. He said "it is more than enough for your top". He said three layers is typical application to build a 17-19' hull that needs to handle the pounding the open waters.
But it is heavy.
I'm happy.
BTW, its in the 80's, rather dry, and no blush showed up at all on this regular laminating epoxy. So another fear is set to rest.
But it is heavy.
I'm happy.
