Flyinjrc74
- Aug 15, 2010
- 2
I am new as of tonight and have some questions...
My real name is Jason Nicodemus from Niles, MI and I am new to boat ownership. I am very mechanically inclined but now I am really baffled!
I bought a 1978 Ebko tri-hull runabout with this 1978 70HP Johnson bolted to the back of it. The boat has sat a couple years and the genious that owned it prior had tried starting it with a screwdriver/shorted out the switch/messed up linkages and the control box would not shift into reverse.
I messed with it for a bit and could not figure the control box out, I put in a new switch but could not get power to engine!
I took the whole shi-bang to a marina in S.B. IN They were able to troubleshoot the problem to one of the cables and the adjustment was off. They got it to the point that it would turn over with the new key switch and cable but the CD3 Coil pack was bad. I found the same year engine in Saginaw,MI and drove up this weekend and bought the whole thing just for parts! I robbed the ignition off of it and installed it on the motor on my boat and within seconds it fired up but the idle was high so I immediately shut it down. I tried again and again without it in water or with muffs on it. Same thing, started and ran fast(It sounded very mean and in time)! I shut it down and used a saws-all to cut my trash container and filled it with water submerging it like it were in the lake!
I again tried to start it again and it would not start up and is now backfiring and smoking alot??? I tried several times to get it to run using the choke and trying to open and close the butterflies for the actual throttle. All we could get was backfiring and smoke!
We have checked the spark(all plugs are sparking brite white), tried starting with fuel line attached and also unplugged? It is getting fuel/it is getting good spark so I am puzzled why it is now not firing in the water.
Then- I moved the throttle forward and back to reverse and now I am back to square one as the throttle control is going back to center and will not go back far enough to go into reverse or center to allow the key to start the engine???
One more thing! The impeller seems to be not operating? When I was turning it over and also when it started there was no water coming out of the exit just below the engine cover on the right side? I will check tomorrow to see if mud daubers may have nested there or possibly a large brown recluse is inside(hopefully not the recluse)?
I appreciate any experience or answers in solving my problems with this engine. I have a whole engine at my disposal to rob parts from if necessary! The only thing wrong with the parts motor is no compression in the center cylinder!
Thank you very much!
