Pro xs stalls at idles/ Sluggish acceleration
sdbryant179
I have a 2012 115 pro xs 2stroke. Did a power head rebuild. Only starts under fast idle. Once I bring it back to neutral it shuts off. After a few tries it starts for a brief second without fast idle if I’m quick enough I shift it into gear I open the throttle about half way with very sluggish acceleration for about 2 minutes, then it opens up at 3000-4000 rpm and runs great until I begin to back off the throttle it drops down in power and if I bring it back to neutral it shuts off again.
Chris1956
Honorary Supreme Mariner
Is the stator ign low speed winding working? Was the motor linked and synched after rebuild?
Chris1956
Link and synch is where the mechanic sets the idle timing and synchs it to the carb opening. He then sets the max spark advance, throttle stop and throttle cable position. Every Merc service manual for your motor has the procedure.
It sounds like you need a Merc Service Manual.
sdbryant179
I have two service manuals, it’s fuel injection, I looked through and couldn’t find any info on link and sync. It does state that the power head timing that is usually set through fly wheel markings and top dead center is automatically , no adjustments needed. I am very grateful for your replies!!
alldodge
Thanks, yours doesn't have a IAC, the PCM controls the idle.
Being a optimax need to check your fuel and air pressure. I'm finding fuel pressure should be 90 psi and air pressure should be 80 psi
muc
"Retired" Association of Marine Technicians...
Did you find the cause of why the first powerhead went bad and correct it?
Have you replaced the fuel, oil and air filters? Tried a new set of spark plugs?
Check TPS, don't replace it! test it. idle - 0.17–1.05 VDC / WOT - 3.76–4.64 VDC
Next is fuel/air pressures.
air = 95 ± 1 psi
Fuel/air differential = 14 ± 0.3 psi
mechanical fuel pump = min 1psi @ idle/ max 10 PSI @ WOT
low pressure pump 20–30 psi
high pressure pump 109 ± 1
Check shift switch
