Primer Solenoid
stach1024
I have a 1985 Johnson 50HP. Every time I push in the key to prime engine the 20 amp inline fuse blows. I put a new primer in and still does the same. It starts and runs great when primed manually. Could this be in the key switch? Thanks for your help. I need to go fishing.
bobjoe1
Re: Primer Solenoid
I had same problem and took it to the boat shop and they couldn't find anything. So by accident one day me and a friend were checking it out and had the motor cover off and I just happen to have been looking right at the primer solonoid when I pushed the primer button and I saw a puff of smoke and there went the fuse again. The little wire going to the primer had worn through on the back side and was creating a short. This ruined many a fishing day and just blind luck found it. Shorts are very difficult to find. Good lick.
milmat1
Re: Primer Solenoid
YEP!! The wire to the primer (or at the primer) is shorted to ground...So when you hit the button you are connecting 12VDC straight to ground...
jtexas
Re: Primer Solenoid
Shorts are hard to find if you rely on blind luck. But if you resort to drastic measures, like maybe methodical troubleshooting with a suitable tool such as a 12 pound hammer, or digital multimeter (about $25 at walmart in the automotive aisle), you can track it down.
Sorry, couldn't resist... ;) To answer your question, yes the keyswitch could have developed a short between the C terminal and ground.
ezeke
Re: Primer Solenoid
Disconnect the primer solenoid at the bullet connector on the engine and then push the key in. If the fuse blows, it's not the primer solenoid but something between it and the key switch.
If you have accessories running off the ignition wiring and use the primer solenoid and the starter at the same time, you can easily overload the fuse.
stach1024
Re: Primer Solenoid
Thank to all who responded to my question. You were all right. I'll be fishing tomorrow.
