Primer solenoid assembly for 1988 48 hp Evinrude.
tphoyt
Can’t see a pic if you had one but if your asking about the red lever it would inline with valve body for run position or turned 90deg for manual position.
Ron Wetherell
I live in Florida so I assume I should never need to move it from the normal running position.
Ron Wetherell
I do have a picture attached but the admin needs to "resolve" something before it can be posted.
tphoyt
Pic’s have been a problem for a few weeks now but its being worked on.
The manual position would be for say your battery was dead and you had to start manually.
The solenoid normally works when you push the key in. It acts like a choke only better.
I grew up in Fl and recall some cool mornings in the winter. Even saw snow twice in my 30 years there.
Ron Wetherell
I understand that normal running position would be with the red lever in a straight line with the cylinder body, correct?
