primer bulb wont fill up
jasonmmoore
1985 50hp mercury idles fine, starts fine, no wot but it picks up when i squeeze the primer but then the primer wont fill back up till i bring it back to idle, it has a new portable gas tank and the primer and lines to the engine are new(bought this year) it has ran this way since day one, any suggestions?
Dave1027
Re: primer bulb wont fill up
Is the gas tank vent open and working? Try it with the gas cap off.
jasonmmoore
i tried it with the vent opened a little and opened a lot and with the cap off same thing it has a mercury fitting next to the engine and an omc fitting at the tank probably makes no difference huh
Dave1027
Did you replace the entire fuel line or just the part between the bulb and motor?
jasonmmoore
everything is new from the tank(including the tank) to where the line hooks the the engine
Mi duckdown
Have you tried running the motor with the cowl/ hood off, to see if gas is spilling out of carbs/lines etc.?
You probably looking at a fuel pump rebuild.
roncoop75
New primer bulb eh?
You get that from walmart?
The one I got from there didn't work, brand new and junk right from the start.
If your old bulb isn't falling apart try putting it back in and see what happens.
For the record I'm leaning towards fuel pump also. Don't be discouraged though, they're so easy to rebuild a cave man could do it!
Fed
Got the arrow on the primer bulb pointing in the right direction of flow?
They also work better pointing upwards too.
Mi duckdown
that was what I thought. primer bulb installed backwards.
Also don't buy walmart/Kmart crap. Buy only OEM PARTS.
jasonmmoore
got the carbs built and now no trouble except real slow taking off prop pitch is 10 on a 16 ft bayliner 1040lbs 50 horse mercury is that about right?
Orbit Express
Forget Walmart, KMart, Meiers, and go to a real boat/motor outfitter and get a real motor. Look into anything but a Merc.
Once again, the above poster gives incredibly intelligent & helpful advice.
I'm glad you got it running, Jason. My 15' Renken with the same motor takes of slowly. I have a 13 pitch prop. I think it's more an issue of power. 50hp isn't that much...I trimmed mine differently (it's manual trim) and I got it to pop out of the water better. Maybe you could try messing with the trim and see what happens.
Never seen that happen before. One of the little things that can be missed will be missed from time to time I guess.
