FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Find and old Chevy distributor (V8 or V6) doesn't matter year or anything else. Then remove the gear, cap and rotor and hook your drill to the upper shaft. May take some grinding to fit your drill. Make sure all the grindings are washed off before use.
I have no idea Tony, he asked if there was a chance, and I said there was. I have no clue who rebuilt it, if assembly lube was used or just oil, or how long it's been setting. The bearings could be dry as a bone and no oil in the passages or filter. What do you think would happen if it was dry and he cranks it over 10 or 20 revolutions before the oil pressure builds up?
The oil pump shaft has a slot in it. Find a flat blade screw driver that's long enough to extend up far enough so that when it's engaged in the slot, there is enough sticking out of the hole when the handle is removed to chuck into a 1/2" drill motor. Use a fairly heavy screwdriver with a 3/8 or 1/2" wide blade to avoid breaking the screw driver.
For you naysayer's I've been doing it this way for years. I don't think I know of anyone that builds motors that has the special tool.
Just in case though, (trying to cover all the bases here) -- The oil pump shaft is hardened and won't break and I've never broken a screwdriver but if you did you would retrieve it with a flexible magnet pretty easily. You do it the same way you retrieve a distributer shaft pin or broken distributor/cam gear.
You have to have the distributor housing in there to connect the oil passages. using just a screwdriver in a drill will only oil some of the main and rod bearing. Nothing for the cam and lifters.
