Primary and secondary starter solenoid ?
Steven D
I'm working on a1969 Mercruiser 160 inline 6 and have a question about the master/slave solenoid, which is which? I've got one under the manifold and one on the starter and am trying to figure out the proper place to hook in a bump starter....
Thanks,
Steven
Don S
Re: Primary and secondary starter solenoid ?
What is a bump starter?
Assuming :)rolleyes: I should know better) that you mean one of those emergency start packs. You need to hook that to the main battery terminal on the starter.
Steven D
A hand held switch that allows you to turn the starter over while observing the motor.
Thanks,
Steven
dubs283
slave solenoid is the one mounted under the manifold
starter solenoid is mounted on the starter itself
connect your remote start switch to the slave solenoid:
one end on the small post with the yel/red wire, other end to the large post with the red wire
Steven D
Thats what I needed.
Thanks,
Steven
