Price of a wakeboard tower !!!
a70eliminator
Looking at $800-1,500 bucks!! The only way I'll ever have one is to build it myself. Anyone here ever done it or attempted to, want to? I'm thinking aluminum pipe, tig welds, stainless hardware, and powdercoating finish. I wonder if a muffler shop could bend the pipe for me?
I'm just board and itchin to start fabbin up something
erikgreen
Re: Price of a wakeboard tower !!!
I've been looking at something similar for a radar arch.
I don't know if a muffler shop can bend the pipe... maybe if you want it made from the same pipe they use?
Typically the dies used to do the bending have to match the tubing size precisely to avoid kinks. If the outside diameter is different from what the die is meant for, you won't get good results.
What I had decided to use (buy or rent) is a JD squared type tubing bender with the appropriate die. They usually get used for things like making rollcages for sprint cars, and can make just about any bend needed to any angle.
I was planning on bending the tubing, tig welding, and then welding up a support framework for the boat, since the top cap alone won't support the weight (I will tie it into the stringers/transom).
Note that if you use stainless and aluminum in contact with each other, you'll still have the dissimilar metals problem, even though the individual alloys are non corrosive.
Erik
PS: The cheapo "tubing benders" at harbor freight are for pipe, not tubing, so they won't work unless you're making a tower from steel pipe :)
vandy21
check out www.wakeboarder.com' and under the DIY section on the forum. there are tons of custom towers, but you need to become a member to view the picture. Also, if you want a cheaper solution, check out www.diywake.com', theres towers starting at $500.
CapriRestorer
I have seen some inexpensive lightly used ones on Craigslist. I saw one recently off of a new Tahoe boat going for $150 in the Austin Craigslist.
oops!
i saw one on a wake forum. the guy did it outta squair tube. he did a fantastic job! looked really cool... he cut out the name of his bote using a plasma cutter and welded it to the tower. looked fantastic. he did it cheep. and its the best looking tower ive seen.
oops
OhWellcraft
I made one more for skiing so not as high as you probably want, but I had a muffler shop bend up the stuff for me. I used their material though it is thick walled aluminized steel (2 1/2 od). I ended up painting mine as the steel didn't look so hot after I welded the base plates on and rope hook etc. It is not super fancy but it has served me very well for 3 seasons now and I ski very hard putting A LOT of stress on that thing. It has never even winced I also had three tubes with two adults on each behind it and it was fine. By painting it I was able to bondo out all of the welds and smooth everything very well and I was able to match my boats trim color exactly. I think it cost me about 150.00 total. Plus I now have a place to hang gloves, ropes, jackets etc. which helps with clutter. Good luck on whatever you decide to do.
vandy21
^^ do you have any pics of the tower?
