Prkranger2
- Apr 17, 2005
- 35
Is it possible to just use pressure treated lumber for stringers instead of using unpressure treated and fiberglass? I have to replace stringers.
I used standard pt from the local lumber yard and let it dry in my shop from several months to over a year. Center stringer was a 2"x12"x 20' timber. Side stringers were 3/4" plywood. The original floor was 1/2" ply and I upped the size to 3/4" to make up for the low grade lumber. Over kill with wood and glass added approx 100lbs to the boat. I can't tell it. <br /><br />Actually, the cheap ply was excellent. Hardly any voids and one side had no voids. Much better than we used to find years ago.<br /><br />I glassed (1.5oz mat & 18oz woven roven)the stringers (1.5,18,1.5,18)and transom (2 layers 1.5)using epoxy resin. The floor was sealed both sides with thinned epoxy resin and tabbed in around the edges with thickened epoxy and glass strips (1.5, 18, 1.5) approx 8" wide.<br /><br />Here's a pic showing the bottom of the floor after coating with epoxy...lots of it.<br />Originally posted by Prkranger2:<br /> BillP did you put fiberglass over the pt wood that you used? What was the process you used?
Prkranger2 - I also have a McDaniel, an 17' '85 Mark IV F&S. You are the only other person I've ever met that has one. Have you ever found and info regarding the McDaniel company and/or their boats? ANy pointers would be appreciated. Good luck with your restoration.<br /><br />PeteOriginally posted by Prkranger2:<br /> Thanks to you all this is really helpful. I purchased this boat for $250 a 1982 Marc I made by McDaniel boats it is a run about. I have to replace the stringers and floor. I have learned alot the last couple days.
