pre purchase inspec. 1977 25 johnson
m wright
inspecting 25 john. with intent to buy. all has checked well, comp., foot, water pump etc.... noticed a small fuel leak on dry rotted hose. located starb. side crank case housing, mounted top fwd. and just below intake. dont know what it is called or its purpose. info would be appreciated.
Gary H NC
Re: pre purchase inspec. 1977 25 johnson
Is it a small hose that runs to the carb cover? Easy fix.
Probably dry rotted hose..
m wright
yes it is an easy fix, just curious to what its function is . another hose on oppisite side not leaking but is dry rotted. thanks...
