Looking for some help here. New to merc outdrives, not new to boating. All my previous outdrives have been volvos. I find myself with a 28' carver santa cruise that was originally powered with a pre alpha and a 305. I have a very low hour 350 merc ready to drop in it but I need to upgrade the outdrive. I found a low time bravo 3 a guy pulled out to go with a bigger diesel in his boat and I can get the complete set up cheap. It has 1.65 gears in it and I am not sure of the SS props. He had it behind a 270 hp diesel.
Question 1) are the transom holes the same for the pre alpha and the bravo?
Question 2) with this gear ratio what props would you start out with? The boat weighs 7200 dry
Question 3) will the bell housing from the pre alpha work with the bravo 3 or do I need to order one?
Question 4) The diesel used single exhaust and I know I would need to go dual on the y pipe. Thoughts on just ordering a new y pipe versus going with a lifted thru transom exhaust system? I have LOTS of room under the deck and can get in there and hold a dance if I wanted to so space and ease of working on the engine is not an issue. I wish all I/O installs have the room under the deck that this boat has. I would have busted a lot fewer knuckles and not need near as much rum or vocabulary to wee wee on the boat designers.
I have been searching the net for 2 days and my head is hurting from all the various searches I have done to find this info so I am hoping ya'll can take some pitty on me and help me out here with some straight answers.
Leni
Leni
