Re: Pre-alpha to alpha
sorry I can't be more specific
Ayuh,... Why not,..??
For a 1966, you'll need to swap out the Whole drive, from the rear motor mounts back...
That'll include redrilling atleast 2 of the transom holes...
Then your motor may/ probably won't mount up to the new inner transom plate...
So,... You'll need a new flywheel cover for the motor to attach to the drive...
Then the exhaust manifold won't line up,..
So,.. You'll need a new exhaust manifold...
Basically, you need a new Complete driveline, from the pulleys to the prop....
