powerhead what year is it?
jhace75
Bought a 140hp powerhead to replace my 140hp late 70's model straight six. well started to switch parts over and the ports for the fuel pumps were not drilled out so I figure it must be a newer model but can't figure out what year.the only numbers I can find on it are on the intake wich are 9737328
Take a look at the bottom of the blocks and see if the gaskets would be the same to bolt it to the exhaust housing.
jhace75
Yeah that part looks the same I also noticed today that the start mount is clock in a different position
The inline sixes had different fuel pumps, depending on year and serial group. I would think swapping the transfer covers over would solve that issue.
jhace75
That's what I thought to but there no holes drilled in the block for the vacuum to make the carbs work ...I'm looking to sell it and just get the right one but hard to sell when idk what years it is thank you tho
Fuel pumps normally run off brass fittings on the transfer covers. Another type has the fuel pumps mounted on the transfer covers.
jhace75
If I could figure out how to put pics up I wouls show but ot keeps saying they a re large
