kandil
Thread starter- Joined
- Aug 8, 2008
- 567
I have a 1994 90HP Force that has low compression on piston #1 it has some damage on the corner of the piston and the cylinder wall has some glazing on all the pistons and I figured that to remove the powerhead and hone all cylinders and get all the parts will end up coasting too much!!+ the time so I found a 1994 force 120HP complete powerhead with 150 psi on all pistons and very Little hours for under $800.So my questions are 1-is the swap possible? 2-is it going to fit? and 3- is the gear ratio the same for this outboards? 4-or should I rebuild my powerhead?
thanks for the advice in advance
