powerhead installation
ralph2830
I'm getting ready to reinstall a rebuilt powerhead on a 89' 85hp Force. do I need to purchase gaskets from Mercury Marine for this? The manufacturer had used what looked like an RTV adhesive when I pulled the powerhead. Whats the best way to go?
eurolarva
Re: powerhead installation
Yes you should use factory gaskets and also use a non hardening permatex. NAPA sells one called aviation permates. I believe it is a number 3 type permatex and comes with an aplicator brush. If you dont use gaskets you run the chance of exhaust leaks.
ralph2830
Thanks for the info. I'll go to a marine dealer and pickup or order a set.
WillyBWright
The gasket you are looking for may not exist. They did use black RTV silicone on many models.
eurolarva
Post your model number. Look at item 53 on this LINK . This is off a 1989 85 HP force however there are about 10 different models for that year.
ralph2830
Thanks Eurolarva, model # is 856A9H. I was able to order the gasket locally, Item 53 on your link is the part that was ordered. They did use black RTV as Willy stated, but I feel more comfortable using a gasket if available. The exhaust tube, however, does have to be sealed with RTV
