Would a power trim off a 70hp merc fit or work on a 50hp merc?
J jaybrown Banned Joined Mar 23, 2013 Messages 75 Apr 4, 2016 #1 Would a power trim off a 70hp merc fit or work on a 50hp merc?
merc850 Commander Joined Jul 7, 2010 Messages 2,046 Apr 6, 2016 #4 Yes if it's the external twin ram. Here are some instructions in case you don't have a manual. Don't try to drive the tie bolt out of the spacer, just remove one clamp bracket and the 2 nuts and pull it out.
J jaybrown Banned Joined Mar 23, 2013 Messages 75 Apr 6, 2016 #5 So do I have to chage the mounting bracket from one to the other?
merc850 Commander Joined Jul 7, 2010 Messages 2,046 Apr 6, 2016 #6 No just the cylinders but the PT has a longer tie bolt that goes into the bottom of the cylinder bracket.
J jaybrown Banned Joined Mar 23, 2013 Messages 75 Apr 6, 2016 #7 Ok the 50hp dosn't have power trim I want to put power trim on it hope we are on the same page
J jaybrown Banned Joined Mar 23, 2013 Messages 75 Apr 11, 2016 #8 So wht type of oil should I put in the pump?
